SQLite for Autolisp
I've made a new build of SQLite for Autolisp for V13 64bit, here is the link
http://www.cadext.com/downloads/SQLiteLsp.zip
SQLite is a software library that implements a self-contained, serverless, zero-configuration, transactional SQL database engine. SQLite is the most widely deployed SQL database engine in the world.
SQLiteLsp is a BRX module with the SQLite engine embedded inside, it's a crazy fast database for lisp
Enjoy
Awesome, thanks Daniel.
Just to clarify you've included 32/64 bit builds for AutoCAD 2004 - 2014, BricsCAD V9 - V13, along with the source code.
I'm are of your posts on the SQLitelisp
http://bricscadapi.wordpress.com/2010/08/25/sqlite-and-lisp-part1/
http://bricscadapi.wordpress.com/2010/08/25/sqlite-and-lisp-part-2/
Is there anything else available for those looking to get started?
Regards,Jason Bourhill
Added versions for 14x86 and v14x64, same link as above0
