Wrong draworder when inserting Blocks
When inserting Blocks with hatches/Solids in BricsCad V12 the hatches are displayed on top of the draworder, making underlying geometry invisible. This behavior did not occur in V11. Am I missing a certain Setting/Systemvariable?
I have to add the Problem happens when the Block with the hatch/Solid is nested in anaother Block and I try to insert it.0
Your problem seems related to this bug:
My Support Request (SR38032):
I notice that if you copy block definitions between drawings using one of the methods listed below, the draworder is lost.
Only if you use the "classic" wblock-and-then-insert-from-disk-method is the draworder preserved.
Methods that lose the draworder:
1. Copy+Paste a block reference.
2. Drag-and-drop a block definition in the Drawing Explorer.
3. Insert using the Block Manager.
Answer from Bricsys:
Thank you for pointing this out. I confirm the problem. We plan to fix it.0
