SNAPUNIT = GRIDUNIT
Is there a way to make SNAPUNIT = GRIDUNIT automatically (meaning I don't have to manually change SNAPUNIT if I change GRIDUNIT) ? In AutoCAD this was done simply by making SNAPUNIT = 0,0 but in BricsCAD that deactivates grid snap...
The Snap option of the Grid command synchronizes the grid spacing to the Snap spacing.0
Thank you Louis.To expand this for anyone else confused about this, setting SNAPUNIT to [desired grid size] and GRIDUNIT to 0 synchronizes the two (ignore the first post, I had it backwards there, which is why I couldn't get it to work, of course!). As Louis taught me, GRID > SNAP is the quickest way to do that.0
