File open
Hi, in V7 I could make a menu with some start templates just by adding _open;drawing1.dwg at the command line in the definition.
How do I achiev this in V13.
[code]^c^cfiledia;off;_open;X:/Path/Drawing1.dwg;filedia;on[/code]
Although I would use the NEW command for templates.0 -
Roy !! FANTASTIC !
You finally answered my question from 2005. http://forum.bricsys.com/discussion/5842
GREAT I'm gonna use it.
Patrik,
as Roy hinted you could achieve the same by using templates. You can convert any drawing to a template by using _SAVEAS, then selecting the .dwt file option. You can also simply rename .dwg -> .dwt to convert them to templates.
The major advantage of a template (.dwt) over a drawing (.dwg), is that BricsCAD will start a new drawing based on a copy of the the selected template. This removes the chance of accidentally mucking up the original template file. If you instead open a .dwg, then you must make sure you first save it as something else, which is easy to forget. Using templates instead of .dwg becomes much more important if you have multiple users.
The following _SETTINGS control the default template, and location of your template files.
BASEFILE
TemplatePath
Regards,Jason Bourhill
YES ! I have already done this. The main thing is I never realized the functionality was there. I never saw the NEW command changing shape. It has as far as I knew always worked as QNEW does now.0
