how to batch export .dwg files into pdf
You can use Publish command and use PDF printer, like for example PDF Creator.0
publish command is not able to convert autocad as searchable pdf?
export command is able to convert pdf (searchable by font remapping).
but unfortunately there is no batch export command.
how to batch print dwg files using bricscad?
i got solution to my problems.
geotools GT_MULTEXPORT command is able to process all the selected files and able to export the same to pdf.
You can do it easily by PDF Forte. I always use PDF Forte. THis can convert any file to pdf. Like JPEG, PSD, excel, word, gif to pdf. I will suggest you PDF Forte cause it easy to use. You can use trail if you like then you can buy it from their site.
