exporting of pdf is resulting in large line size
i am able to export dwg file to pdf,.
in this process i am getting extra large lines than what they appear in preview? is there any setting i am missing.
i am attaching the snap of exported pdf file.
  •  starting with the obvious I guess what is the line weight in properties when you click on the line?
  • line weight is bylayer.
  • Same thing happens when I use export to pdf.
    Line thicknesses are correct using creators such as Pdf-xchange and the file sizes are much smaller.
  • Print the file to PDF using Acrobat or one of the freeware PDF writers.
    If the lines are still too thick, there's something in your lineweight/color/layer settings that needs to be adjusted.
    If not, it's a bug in the PDF Export routine, and if you file a support request and attach the drawing they'll find the problem and fix it.
