Modify toolbox
Version 13.1.19 build id 42493 revision 28847
Kubuntu 13.04
The Modify Toolbox that is usually on the very right side of the Bricscad Window vanished when I tried to grab it for moving around.
Now it is impossible to get the toolbox back again. If the toolbox is turned of the drawing widow is attached to the right side. If the toolox is turned on a space of the size of a toolbox is enabled but no toolbox shows up.
Kubuntu 13.04
You can try using the "customize" command.
In the Toolbars tab of the customize dialog, locate the Modify toolbox, and change its position.
If that does not help, please file a support request.0
