dwg not converting to dxf
Hi all, I am trying to  send a dxf to get some CNC cutting.Thing is I save the drawing as "autocad binary 2007 dxf"  when i check properties in the saved file it says it is "autocad LT dwg" am wondering where the autocad is comming from but more imortantly why is says the file extension is dwg when it was saved as a dxf?
Any ideas?
  • Hi, Stephen,
    I just tried on my machine : "SaveAs" -> "2007 binary dxf" -> result was "test.dxf" ...
    Where do you see .dwg file extensions ?
    Does your Windows Explorer shows file extensions ? It should do so - otherwise you can not distinguish "test.dwg" and "test.dxf" as extensions are omitted
    (btw., terrible safety fault by MS - no longer default in Win 8)
    Also, where do you "check properties" ?
    Many greetings !
  • Hi Torsten,
    when I save it as dxf i just right click on the resulting file right click and check properties, is there a better way. But I have sent the drawing to 2 cnc guys who say they are not recieving dxf files but dwg's. They use cnc nesting programs which require them to be dxf. I have resaved and resaved but it makes no differencem it seems.
  • If I check the file properties of an AutoCAD 2007 Binary DXF file the file type is mentioned as: BricsCAD Drawing Exchange Format file.
    I believe this is something that is stored in the Windows Registry.
    @ Stephen: have you (previously) installed some Autodesk product?
  • @ Sephen: Have you tried sending AutoCAD 2007 ASCII DXF?
  • Hi Roy, yes i have but I though I deleted it, must be a reminant hey?
  • Oh the other thing I did was to install a "select similar" 'plug in' that said it was an autocad light priduct in one of its files
    Cheers
  • Dear Stephen,
    please ensure that your Windows Explroer shows file extensions !
    Under option ... by default it is off ...
    Then, using "SaveAs" with "2007 binary dxf" will create a DXF file ... if you open that by notepad.exe, you should see
    "AutoCAD Binary DXF" or similar ...
    Also, as Roy suggested, try "ASCII DXF" ...
    In Explorer -> Properties of a selected file read information from Registry ... so the given information could be affected by other (CAD) applications :-)
    Only reliable :
    - file type like "test.dxf"
    - having a look into using notepad.exe
    Hope this helps ?
