editing default.pc3 file
in Other
I know this is probably elementary but is there a way to edit the default.pc3 file so when I hit quickprint it'll print in landscape mode instead of portrait? Or is there a way to program quickprint so it use a different plot setup?
QPRINT prints to your default pc3 printer, using, I believe, the last used print settings.
(I would advise use PRINT command.)
Cheers
