Note for running Bricscad on Fedora 19
Fedora 19 rocks and is nowhere near the initial train-wreck that 18 was, however:
Bricscad complains about libgnutls.so.26 missing and refuses to start. I've found that creating a symlink pointing at libgnutls.so.28 (which is itself a symlink pointing at libgnutls.so.28.19.0) takes care of the problem. Not sure if there will be resulting chapoo issues as I don't use that functionality at this point.
That is, as root:
# ln -s /usr/lib/libgnutls.so.28 /usr/lib/libgnutls.so.26
Adding a symlink in /usr/lib64 is unnecessary; the above works for i686 or x86_64.
