Align multiple
Good afternoon, there some trick to align multiple objects at once to a single reference?
Thanks
  • The problem I see is that you propably want a separate rotating piont for each object.
  • ... And also an object can have more than one logical base angle.
  • gracias por preocuparos por mi "problema".
    De momento solo queria alinear varios objetos a un lado (izquierda, derecha, arriba o abajo).
    He encontrado un lisp que lo hace.
    Si quereis lo adjunto.
    (si puedo hacerlo)
    Perdonad está traducido con el google traductor
  • Thanks for caring about my "problem".
    For now I just wanted to align multiple objects on one side (left, right, up or down).
    I found a lisp that does.
    If you want it attached.
    (if I can)
    Pardon is translated with google translator
  • I guess Patrick and I were thinking of a different type of align. As in more along the lines of the _ALIGN command.
