STL export?
 How can I export my model to STL ?
  • If your system supports python 2.6, you could just grab a copy of blender 2.49, import your data written in r12 dxf format, and re-save as STL.
    Unfortunately, the dxf importer in later blender releases is broken for 3d data (and not likely to get fixed).
  • For 3D data conversion I'am using this software: http://www.tb-software.com/products_2.html. 3DWin works well under Wine. I don't tested full Rheingold3D, however, but you don't need it for conversion. You can export .stl from 3DWin (also not tested by me, I'am using it for conversion to .obj and follow-up import into Blender).
  • Reading V14 online manual, i see STL export is new in V14 :)
    -great; i have an old reprap to assemble when i have learned to CAD
    I found an online graphical STL viewer here: http://gcode.joewalnes.com/
