Polyline with width > 0
when you move or copy a polyline with width greater than 0, it loses its width.
  • I tried this and it works fine for me. Im using v3.J Templeton
  • But the last commercial version is 2.2.0027. Could someone test it in this or earlier releases?
  • I am using same version as you and am not having the problem you encountered.Sorry.
  • Nor am I (2.2.0027 / W98)
  • Do someone test it on Windows 2000 o XP platform?
  • I have win 2000 pro. intellicad v.27. I have moved polylines with widths greater than 0, i have also moved polylines that have 2 different widths and the width factor has stayed the same every time. My suggestion is to reinstall your program and try it again. Also does it do it in every drawing that you work in or is it in just one drawing that you are having the problem.
