Aspect ratio on imported files
HI , Im unable to find the nice little feature of differentiating aspect ratio when scaling jpg/PDF/BMPs . Anyone have an idea is it possible.
I get a lot of handmade drawings sent that I need to trace. Often they are in bad scale and I really need this. /P
I don't know of an application off hand, but creating a block of the image may help you. Once the block is created, you can scale it independently along the X, Y and Z axes via the properties panel.0
That's the problem. I cannot seem to create the block. Bill0
THX it works. Bill just rightclick the image and past as block.0
@ Wilbur: I have seen your two 'block' questions in the Public User Feed. Maybe you should start a new topic and explain in detail what you are doing.0
