Tangent problem
div> i want to draw a line tangent to a circle with an angle of 8.5 degree as drawing show (draw using autocad). When i try to draw on Bricscad the angle come out will be different when it measure it but in Autocad is ok. Command it use is on on the snap to tangent and put @10<81.5. I using Bricscad V12. I had try on Bricscad V13 also the same.
            From the Release Notes:
'Version 13.2.5
Fixes
SR37485 - TANGENT SNAP: fixed the construction of a line tangent to a circular arc when deferred tangent snap is used for the first point of the line and relative polar coordinates are entered for the second point of the line.'
You have probably tested this with an earlier version.
On V13.2.10 it works perfectly.0
