Paper space Model space lineweight
Hi all I have seen this question before but cant find the post. I get the line wieght correct in model space but it does not show in paperspace. Can someone please clarify?
Thank you
  • Hi Stephen,
    try turning PSLTSCALE to ON. When on, the view port scale will be taken into account when applying the LTSCALE. In other words the linetype will display as if you had drawn it in paperspace, dispalying the same no matter the view port scale.
    Attach some screen grabs to illustrate
    CAD Concepts
  • @ Stephen: This may be a scaling issue. Try creating a 1:1 viewport displaying entities with a 2.11 mm lineweight.
  • Thanks Jason - just discovered PSLTSCALE. In my case I need it OFF to ensure dashdot lines are printed correctly when scaled down to A3/A4
    This has been a minor pain for years!
