BRX vs. TX
Hi guys,
I am trying to make my C# work with Bricscad. All works fine, I can even step debug trough my C# code but have a question related to libraries my project is referencing.
Reading
http://www.bricsys.com/bricscad/help/en_US/V12/DevRef/index.html?page=source/TX_01.htm
I learned I need to refer three dlls: 'BrxMgd.dll', 'TD_Mgd.dll' and 'TD_MgdBrep.dll' - this works very well. Then I investigated C# and a VB.NET sample project calling the managed wrapper classes shipped with Bricscad. I found that all sample projects are referencing Teigha library. Then I read
This compares ARX and TX (where TX has some relation to Teigha libraries?) and suggests that there is better alternative: BRX
Not sure if this is clear enough. Could you please add a little bit more explanation? To me it looks like using TX makes my application incompatible with AutoCAD. Although I am not intending to use AutoCAD I would like to learn more principles behind and make a strategic decision when starting with my application.
Many thanks for your effort.
Best regards
Jiri
Reading
Best regards
Jiri
I always think of .TX as an interface to the database whereas, BRX interfaces both the application and database.
IMHO, if you want to work in C++, BRX is going to give you the most bang for the buck.Cheers
Dan0 -
Do I have to use Teigha libraries when using C#?
All C# examples shipped with Bricscad refer to Teigha. To me it looks like it is required.
Not sure if I understand it correctly.
Many thanks.
Best regards
Jiri0 -
Yes you need both, TD_Mgd contains wrappers for Database objects and BrxMgd contains wrappers for Application objects.
TD_Mgd is quite a different animal than native coding in .TX, so the comparison you read regarding
.Brx vs. .TX is not relevant for .NET.The .NET API (BrxMgd , TD_Mgd and TD_MgdBrep) is written to be code compatible with other platforms so as
to make porting applications easy, However, .NET applications can never be binary compatible due to references.Cheers
Dan
many, many thanks
regards
jiri0
