section trough 3D solid using C#
I created 3D solid and want to create a section trough it. In Bricscad command line I do '_section'. It prompts me to select the entity. Then it prompts me for 1st, 2nd and then 3rd point of my section plane and it creates new entity of Region type.
I would like to achieve the same using C#. I added all 'using' statements as in provided example. It is pointing to Bricscad and Teigha libraries. Then in my void I am getting points from the user:
[code]_AcEd.PromptPointOptions pntOpt1 = new PromptPointOptions("Get 1st point at roof base (it will be an origin of newly created local coordinate system). ");_AcEd.PromptPointResult pntRes1 = editor.GetPoint(pntOpt1);_AcEd.PromptPointOptions pntOpt2 = new PromptPointOptions("Get 2nd point at roof base (it will point +x direction of newly created local coordinate system). ");_AcEd.PromptPointResult pntRes2 = editor.GetPoint(pntOpt2);[/code]
It works as expected. Then I did the following:
[code] Point3d startPoint = new Point3d(pntRes1.Value.X, pntRes1.Value.Y, pntRes1.Value.Z);Point3d endPoint = new Point3d(pntRes2.Value.X, pntRes2.Value.Y, pntRes2.Value.Z);Point3d lastPoint = new Point3d(pntRes2.Value.X, pntRes2.Value.Y, pntRes2.Value.Z+1000);Point3d[] myPlane = new Point3d[3];myPlane[0] = startPoint;myPlane[1] = endPoint;myPlane[2] = lastPoint;Point3dCollection pt3d = new Point3dCollection(myPlane);Vector3d vct3d = new Vector3d(0, 0, 1000);Section mySection = new Section(pt3d, vct3d);mySection.Name = "TRUSS0010"; ccclsCadUtils.AddToModelSpace(mySection);[/code]
It created Section entity rather then region as I expected when using Bricscad command line. Is there any way I can
create region similarly as when using Bricscad command line? I would like to have some documentation or examples.
If it was possible to purchase some textbook or manuals that would be great - just need to speed up the process of
learning.
Many thanks
best regards
jiri
learning.
Many thanks
best regards
jiri
Jiri,
try to use this code and the result section entity will be a region...
Solid3d solEnt = tr.GetObject(objId, OpenMode.ForRead) as Solid3d;
Region reg = solEnt.GetSection(sPlane);
btr.AppendEntity(reg);
tr.AddNewlyCreatedDBObject(reg, true);
hope this helps0 -
just a small code addition ...!!!!
get the plane from user...
Point3d p1 = new Point3d();
Point3d p2 = new Point3d();
Point3d p3 = new Point3d();
p1 = ed.GetPoint("Pick 1st Plane point :").Value;
p2 = ed.GetPoint("Pick 2nd Plane point :").Value;
p3 = ed.GetPoint("Pick 3rd Plane point :").Value;
Plane sPlane = new Plane(p1, p2, p3);
tr.AddNewlyCreatedDBObject(reg, true);0 -
Hi Konstantin,
many thanks for your advice. Thanks to it I managed to get it work.
Best regards
Jiri0
