DESCoder
What is the purpose of adding text files into  a prv file when creating a DES container? How can you use these files from Lisp?
Regards
Alf
  • From AutoLISP documentation :
    (vl-get-resource text-file)
    "Returns the text stored in a .txt file packaged in a VLX"
    So developers can put whatever helpful informations and/or application-related data into that .txt file,
    and retrieve them at runtime, rather than to have this as external (visible + editable) file on disk.
    Besides, AutoLISP FAS/VLS project definitions in .prv/.prj supports this feature, and as DEScoder wants
    to behave compatible with -prv/.prj files, this feature needs to be supported
    (developers then can use a single .prj/.prv project for both platforms).
    I hope this explains well enough ?
    Many greetings !
  • Thank you very much, Torsten.
    I completly overlooked that possibility.
    Alf
