Move Attribut-References with VBA
Hello out there,
I am trying to move Attribute-Refernces in certain blocks via VBA.
This is how far I got:
Public Sub MoveAttribute(dblXOffset As Double, dblYOffset As Double, strAttribute As String, strBlock As String)
Dim MyObject As AcadObject
Dim MyBlockRef As AcadBlockReference
Dim MyAttRef As AcadAttributeReference
Dim myY As Double
Dim MyX As Double
Dim MyAttributes As Variant
For Each MyObject In ThisDrawing.ModelSpace
If MyObject.ObjectName = "AcDbBlockReference" Then
If MyObject.Name = strBlock Then
Set MyBlockRef = MyObject
MyAttributes = MyBlockRef.GetAttributes
For Each MyAtt In MyAttributes
If MyAtt.TagString = strAttribute Then
Set MyAttRef = MyAtt
MyX = MyAttRef.InsertionPoint(0)
MyY = MyAttRef.InsertionPoint(1)
MyX = MyX+dblXOffset
MyY = MyY+dblYOffset
MyAttRef.InsertionPoint(0) = MyX
MyAttRef.InsertionPoint(1) = MyY
MyAttRef.Update
MyBlockRef.Update
End If
Next
End If
End If
Next
End Sub
The program runs but the Attributes don't move.
I am using BricsCAD 10.4.11.
BTW: Are there any recommendations for documentation of the BricsCAD SDE.
Thanks in advance and
Best reagards
Roman
Howdy, Stranger!
