Attribute rebel
Una consulta:
Tengo un bloque (un cajetin) con atributos, que inserto en distintos formatos.
Si ahora modifico el bloque-cajetin, y le quito algun atributo, y lo re-inserto en el plano,
me pide redefinirlo y acepto, pero no me borra el atributo antiguo. Si lo que modifico es el dibujo, entonces sin problema. Pero un atributo no puedo con él.
Alguna sugerencia?
A query:
I have a block (a box) with attributes, which insert in different formats.
If we now modify the block-slipcase and remove some attribute, and re-insert into the plane,
redefine and accept calls me, but I deleted the old attribute. If you modify is the drawing, then no problem. But I can not attribute to him.
Any suggestions?
did you called 'attsync' ?
You have to syncronize the inserts with the Blockfefinition.
Maybe than it's working0 -
Martin, muchas gracias.
Era justo eso, tu rapida respuesta me ha quitado un trabajo tedioso para hoy.
Lo tendre en cuenta para el mañana.
Gracias otra vezMartin, thank you very much.
It was just that, a quick response has taken away a tedious job for today.
I'll have it in mind for tomorrow.
Thanks again0
