Bricscad 3.2.13
in Linux
Guys, has anyone got the 3.2.13 up and running ? How is it going ?
My install proceeded ok. Bricscad starts and will open drawings. But any attempt at editing or creating 2d elements causes the screen to flicker and the osnaps to jump around. Single lines quickly become multiple lines on my screen. Something is not quite right on my system. This by the way, is ROSA Desktop Fresh R1 release 2012.1 for x86_64, derived from Mandriva OS. I tried downgrading the Radeon fglrx driver but that did not do anything for me.
Any ideas ?
Try to change the GLSWAPMODE system variable to all values in range (0,4) and see if a particular value solves the problem (this can be done by typing GLSWAPMODE in Bricscad command line).0
Thanks for this suggestion. Setting GLSWAPMODE to 0 works best on this system. I need to conduct further testing, but the indications are good.0
