Stretch/move objects
If I move an object, the moved object stays not visible
Also stretch, stretched object not visible.
An if moved, no idea how far moved cause the object that is moved is not visible during the move.
DRAGMODE system variable ? Maybe set as 0 mistakenly ?0
Ah indeed.
Thanks Torsten.0
