Extrude in vertical direction using C#
Hello everybody,
just a quick question regarding using Extrude command from .NET environment. I would like to extrude a region in vertical direction similar to Bricscad command Extrude/Direction.
I did:
                            Region regi = (Region)acTrans.GetObject(ids[i], OpenMode.ForRead);                            Solid3d pSolid = new Solid3d();                            pSolid.RecordHistory = true;                            pSolid.Extrude(regi, 1000, 0);
This extrudes my region perpendicular to the plane of region. I would like this to be in vertical z axis.
Not sure what the most efficient way is.
Please advise
many thanks
Jiri
  • try defining the extrusion direction you wish by picking 2 points....
             Vector3d  dVector = new Vector3d();
             Double  eXheight = 0.0;
    // Select the wished extrusion direction
             Point3d p1 = ed.GetPoint("Start point of extrusion direction :").Value;
             Point3d p2 = ed.GetPoint("End point of extrusion direction :").Value;
    // the direction vector
             dVector = new Vector3d(p2.X - p1.X, p2.Y - p1.Y, p2.Z - p1.Z);
    //   ......selection set in editor
             SelectionSet ss = pSelres.Value;
             ObjectId[] idarray = ss.GetObjectIds();
             Entity[] lps = new Entity[ss.Count];
             Entity regEnt = trans.GetObject(idarray[0], OpenMode.ForRead) as Entity;
    //// create the extruded solid using your selected region ...
             Solid3d sol = new Solid3d();
             sol.CreateExtrudedSolid(regEnt, dVector, new SweepOptionsBuilder());
     // ... and add it to the modelspace
             ms.AppendEntity(sol);
             trans.AddNewlyCreatedDBObject(sol, true);
    hope this helps !
    Regards
  • Hi Konstantine
    many thanks. You put me on the right track.
    Making progress now.
    Best regards
    jiri
