Wipeout Frame Visibility V14
Just downloaded and installed V14 and now I cannot control Wipeout frame visibility using Frame ON/OFF. Has anyone experienced this problem?
  •  Yes, I have the issue on my Desktop and Laptop.  Filling in a support request now.
  • There seems to be a strange interaction with the "Underlays/Frames" value under Settings. Toggling the setting between 0 and 1 (or 1 to 0) allows you to then switch the frame visibility by toggling the Wipeout/Frames command (On/Off).
  •  Fixed in 14.1.02 for anyone who is interested!
