Windows NT 4 SP 5
Hi, Need help here.True type fonts filling does not show black color on Preview/Plotting eventhough output color is set to black. When using Win 98 it works fine.Also, I am still getting problems with the UNDO command (intermittent error). It does not UNDO my previous command but other commands which were done a few steps back.Thanks!
Hi, Need help here.>>True type fonts filling does not show black color>on Preview/Plotting eventhough output color is>set to black. When using Win 98 it works fine.That is strange. color 7 ? >>Also, I am still getting problems with the UNDO>command (intermittent error). It does not UNDO>my previous command but other commands which were>done a few steps back.v2.2.0025?Please send a step by step description so i can reproduce it.v25 has a bit strange behaviour with the old 'pan' command: it's ignored.But this is not critical. I know of no serious undoproblems ( redo that breaks) in the user interface, so i can use your report.regards, sander, bricsnet
