release 3.1.0005
Ok,you had to wait for this one, but here it is.Release 3.1.0005 is out. A number of complaints have been handled. Not all. Downloadable athttp://corporate.bricsnet.com/about/support/newversion3.jsp?site=1.The cad department has gone independent and is now called BricsCAD. This entails a lot of changes, and the release still refers to Bricsnet but that will change. regards,Alexander Van Heuverzwyn, BricsCAD
Thanks!
hi..i´ve installed the new version and it´s running with no problems....!just one question: inthe readme of latest changes you say there: ACIS Viewing : Viewing and printing of ACIS entities stored in a DWG file. What is it , what can i do with it ?And the new group command is working fine but has no toolbutton ? ..i can built one on my own...or is there a hidden import utility or so?
Downloaded 3.1.0005, removed 2.0.****version with great difficulty via winndows explorer, control panel did not work at all, locking up machine. Run install.exe, dialog box opens, click "next" and it goes off on it's own, dialog box dissapears and then NOTHING!All programs except explorer and systray are closed! Suggestion!!!!!!!!!
Sander, Thank You!PLease disregard priooor message. Removed all the intellicad folders via windows explorer, performed disk cleanup, scandisk, and then defrag. (Running on Win98) Went to site and doownloaded ver. 3.1.0005. Installation went as smooth as I am used to from Bricsnet or BricsCad. I'll give it a whirl. Thanks again.Al Pepling
If it's a 2.0 version of intellicad i would indeed uninstall first.
