(command "line"
What I know is otherwise runable LISP code, the (command "line" ... embedded in the code will not work for perhaps known reasons. If so, is there any knowledge of this out there to share?The programming is intended to draw many lines, but the program stops and leaves two points w/ grips, that a line should join.Such a simple action to perform is basic for users to develop applications. So what Goes?
