IGS export in V14
Is it possible to get the export functions for STP and IGS enabled in the trial version of V14? I have a platinum V13 license, however I would like to evaluate the 3D export capabilty of V14 but it seems restricted in the trial version? Barrie
  • The import/export of STP and IGS files is enabled by the Communicator module, which needs to be installed separately. You can download the installer from the Bricsys website at http://www.bricsys.com/en_INTL/bricscad/communicator/. Make sure BricsCAD is not running during the installation. When the installation is finished, launch BricsCAD and activate the Communicator trial license in the Help menu.
  • hello Louis
    Thanks for the info, I will do as you say.
    Barrie
