Annotative: How to create (m)text entities with multiple anno scales?
I am experimenting with annotative texts. One of the things I am looking for is the ability to create (m)text entities with multiple annotative scales. If I use a text style that is annotative the current annotative scale (CANNOSCALE) is automatically added to new (m)text entities, but it seems you have to manually add additional scales. Is there a way to create new entities that automatically have multiple annotative scales?
Hi Roy,
ANNOAUTOSCALE (System Variable)Updates annotative objects to support the annotation scale when the annotation scale is changed.
Type: Integer Saved in: Registry Initial value: -4 When the value is negative, the autoscale functionality is turned off, but the settings are maintained:
ANNOAUTOSCALE doesn't look to have been implemented as yet in BricsCAD. You need to instead use _OBJECTSCALE to apply your annotative scale manually. That said automatically applying all the annotative scales isn't that desirable unless you have first used _SCALELISTEDIT to remove any unwanted scales. When using annotative scaling you really need to have an idea of the scales you are likely to use when creating your layouts.
Regards,Jason Bourhill
Thank you Jason, but ANNOAUTOSCALE is not exactly what I am looking for. With that variable you still have to do something after creating the text entities. I was hoping for a CurrentAnnoScaleListForNewEntities (CANNOSCALELIST?) type variable that you would set to the correct value before creating the entities.
But you are right that working with annotative entities without a good 'policy' is probably a bad idea. I would be interested in knowing how various companies 'cope' with annotative entities.0 -
BTW: What does 'objects that support the current scale' mean. Are there objects that support only certain scales?0
