tools - distance between crossing lines in 3d space
tools_wmlwdp_bricscad.dll - https://drive.google.com/file/d/0B6iWCl7cxj7deTV0WVh2dEZhV2M/edit?usp=sharing
BrxMgd.dll - https://drive.google.com/file/d/0B6iWCl7cxj7dSkM0eXNpaVBMX2s/edit?usp=sharing
TD_Mgd.dll - https://drive.google.com/file/d/0B6iWCl7cxj7dbUlpTE5RVnYxVUU/edit?usp=sharing
1. Download - tools_wmlwdp_bricscad.dll from https://drive.google.com/file/d/0B6iWCl7cxj7deTV0WVh2dEZhV2M/edit?usp=sharing
2.If necessary
download
3. Command: WML_CLD
4. Press "R" or "H"
5. If "R":
Define First Line:
Select First Point
Select Second Point
Define Second Line:
Select First Point
Select Second Point
2.If necessary
download
3. Command: WML_CLD
4. Press "R" or "H"
5. If "R":
Define First Line:
Select First Point
Select Second Point
Define Second Line:
Select First Point
Select Second Point
2. Command: netload
select ==> tools_wmlwdp_bricscad.dl
3.If necessary
download
4. Command: WML_CLD
5. Press "R" or "H"
5. If "R":
Define First Line:
Select First Point
Select Second Point
Define Second Line:
Select First Point
Select Second Point0
