problem - Setting the UCS to WCS does not work
 Bricscad.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor.CurrentUserCoordinateSystem = Matrix3d.Identity;
does not change the coordinate system
In AutoCAD
Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor.CurrentUserCoordinateSystem = Matrix3d.Identity;
works as expected
  • Hello Valentin,
    this user forum is meant for user-to-user communication.
    To communicate with Bricsys development, please use the support request pages: this sounds like an issue that you may want Bricsys development to correct?
    Kind regards
  •  excuse
    I'm new and do not know where these pages
    "support request pages"
    Kind regards
  • On www.bricsys.com click the SUPPORT option in the black menu bar along the top of the page to navigate to the main Support page - there, click on the blue Support Request button at the bottom left. From there on it should be straightforward.
    Kind regards
