XREF issues w/ v14.1.05 64bit
in Other
XREF not working with any dwg.
Command results in program stalling, no Dwg Explorer / Ext Ref invoked, have to hit ESC to continue.
Command line -XREF works as it should.
Curiously it DOES work on 32bit version on my laptop?
Works alright in my 32 bit version, but inserting xrefs tends to only be a once or twice operation per job.
But I am still often picking up the wrong block when inserting using the popup menu.
Always works on the second try. I know it's not a mis-que.
This is likely because of a problem when attaching xrefs in the drawing explorer when multithreaded loading is on (system variable MTFLAGS > 3). It will be fixed in the next update.0
Correction, we're working on it but it will not yet be fixed in the next update. The short term solution is to disable multithreaded loading by switching off its 3rd bit in MTFLAGS.0
Thank you for the prompt, succinct response.0
PS: MTFLAGS variable setting does not resolve the issue here.0
Please indicate how to disable multithreaded loading0
MTFLAGS=0 disables all multithreading.0
