Can't use 3.1.005
Unfortunately, the image tiles in lisp are now worse than they have ever been, malfunctioning and eventually crashing Icad. I have several lisp routines that depend heavily on Image tiles, so this is a release I can't use. In earlier releases they at least (sort of) worked, even if they leaked memory resources.If you are short of a good test utility for Image tiles, you can try this one:http://home.online.no/~avaernes/pub/lisp/Blib.ZIPFrom the revision history page, I see there has been made an effort to solve the memory leaks, which is greatly appreciated. Too bad it only caused more severe problems.
that is a big bug indeed. Tiles just don't showI made a merge error. It's fixed and we're making an update immediately. I downloaded and installed your utility too. We(that is, the ITC) are working on automated tests that will avoid stuff like this happening.sander
Sander I downloaded the latest version yesterday (Feb23 2002)and still found a problem with the slides. Is there a new location for this updated file?Jim
I made a 3.1.0006 with only this fix. It's beta now. sander, bricscad
