Insert blocks via script . point + label
Hello
I am wondering what would be the easiest and quickest way to create a script for points import, together with their names. So far i came up with this solution (which works so far):
_-INSERT TEST 1000,2000 1 1 0 _text 1000,2000 1 NAME
However this script doesn't create a block and text is not exactly on the points created before + if there would be some shorter way to do it, would appreciate it
Thank you for answers and best regards!
Peter
Peter
