Trace boundaries
Hello all,
Does Bricscad API have some method like Editor.TraceBoundary() in acad?
Thanks!
Best regards,
Dusan Ruzicic
  • To be more precise, I want to get selection that represents boundaries around point I pick. For example, this option exists in built in Boundary command. If you open Boundary command, at top of the dialog you will see option "Pick points in boundaries". When you click on this, you will be asked to select point, and after that you will see the selection that represent closed boundary around the selected point.
    Is there an elegante way to do this in Bricscad? In Autocad there is a method TraceBoundary() that should do this...
    If you can give me any tip on how to solve this, please do so!
    Thanks!
