BKG_TableData & v14.1.10
in Other
I've found BKG_TableData to be an excellent & most useful tool.
It works as advertised on Bricscad v14.1.7 32bit, but on v14.1.10 (x64) it yields error messages on loading (yes, CUI file is successfully loaded). Windows 7.
Wondering if anybody can chime in with their experiences or perhaps Roy can offer his expertise.
Robt thank you for pointing this out. The problem is caused by the new implementation of the (apply) function (since V14.1.09: See SR42556). I will fix this ASAP.0
Excellent.
(PS: It ceased working when updating v14.1.7 32bit to v14.1.10 32bit as well)
Kudos for your contribution.
Kind Regards
Robt thank you for your kind words. This problem has now been fixed.
Link:
http://www.b-k-g.nl/bkg_tabledata.html
My other programs were affected by the same problem. So if you are using any them you will have to update those as well.
Link:
http://www.b-k-g.nl/freeware.html0 -
That was fast...
Thanks again.
Bob
