Help file in IntelliCAD 2000
Tried to load a customized Help file (works in IntelliCAD 98), but every attempted load such as (help "file.hlp") returns nil. Also, the setfunhelp function does not work, (this one did not work in IntelliCAD 98 either). The help file is located in the environment search path.
Intellicad help files are *.chm files (compiled html files) now instead of *.hlp (winhelp files). The help command searches for icad2000.chm in the IntelliCAD help folder.
