Insert Field: Viewport scale Bricscad v12
How can you insert a field with the viewport property "custom scale" in Bricscad v12?
Greetings
  • You cannot...
    Even in current V14 it is not yet possible to tag the CustomScale property of a viewport entity in a Field. Support for this CustomScale property in Fields is scheduled in V14's life-cycle.
