vla-GetCustomScale in BricsCAD
Hi all,
I have a strange problem with GetCustomScale method.
I need to get from LISP level a layout scale. This seems to be pretty simple with such code:
[code]
(setq #doc (vla-get-ActiveDocument (vlax-get-acad-object)))
(setq acLayoutObj (vla-get-ActiveLayout #doc))
(vla-GetCustomScale acLayoutObj 'nom 'den)
[/code][
It works well in AutoCAD - but in BricsCAD I get such message:
[code]
; error : Automation Error. Method [CUSTOMSCALE] not available
[/code]
So such method is unavailable? Strange, because when I try this:
[code]
: (vlax-method-applicable-p acLayoutObj 'GetCustomScale)
T
[/code]
I get TRUE not FALSE.
Could anyone help me with this?
Or maybe anyone has a different way of obtaining the layout scale?
Warzyk
  • This will work on V13 and V14.1.11 (but not on earlier V14 versions):
    [code](setq elist (entget (vlax-vla-object->ename acLayoutObj)))
    (setq scale (/ (cdr (assoc 142 elist)) (cdr (assoc 143 elist))))[/code]
  • We will fix this ... likely that function is declared in COM TypeLib (.tlb file), but implementation seems to have an issue;
    will be no problem to fix.
  • Thank You both for quick answer.
  • Just fixed ... was a typo issue : "CustomSace" instead of "GetCustomScale" was queried from COM,
    which then must fail ... indicated by the error message :-)
    Thanks for pointing us to this issue.
  • Just fixed ... was a typo issue : "CustomScale" instead of "GetCustomScale" was queried from COM,
