Bricscad V13.2.17 auf Linux
Hallo,
bei mir bricht Bricscad immer zusammen, wenn man versucht ein neues Layout zu erstellen bzw. die Seitengröße zu ändern! Woran kann das liegen?
Bricscad auf ubuntu 12.04.3 LTS
  • Excuse me for my englisch, o.k., I have recognized the problem. It is the Cups.pdf Printer. I have installed Cups.pdf by paper dimensions of A0 in excessive length. But Bricscad suddenly recognizes (since update?) these excessive lengths no more! what can i do? I need Papersize A0 in excessive lenght ( 841 x 1500mm). But Bricscad crashed when i use this Format.  I use ubuntu 12.04.3 LTS
  • If you are (more or less) sure that this paper format A0 overlength worked with older BricsCAD versions,
    then please send us a SupportRequest.
    Many thanks in advance !
