Batch Export Multiple DWGs to single Tiff
i want to plot multiple .dwg files into a single .tif file. is it possible?
When using publish command the sheets are output to multiple tifs.
One way (there are doubtless others) is to use the free PDFCreator virtual printer. In addition to PDFs, it can print multi-page TIFF files.
Setup PDFCreator as the printer for the layout/model in the target drawings. Do a Publish and select the sheets as usual. When you publish those, do a "Wait - collect" when the PDFCreator dialog first comes up. On the Print Monitor dialog, do a Combine All (or select and combine as desired) and then hit "Print." The PDFCreator dialog comes up again. Select TIFF from the Profile combo box, then Save and run through the Save file dialog as usual. The result is a multi-page TIFF.
The default is 150 DPI. That can be changed in the printer dialog's Options setting.0
