problem with creating buttons and toolbar
Hi
                    i have problem with creating new buttons
    below two function i use
    functions sometimes works, sometimes not, then bricscad returns
 error : Automation Error 80020009; [IAcadToolbars] Error accessing [ADD] method. ErrIndex=0;
i dont know why, is seems hazard but maybe there is a reason why those function returns error tested on V12, V13, V14 (same results)
           [code]
                     (defun AddButtons (tgname button_lst / Toolbar newToolbarButton) ; tgname - toolbar group name button_lst - list of buttons
                         ;;;; Createas buttons in toolbar group
                         ;;;; example
                         ; (AddButtons
                         ; "DJTT"
                         ; (list   "Apps"
                         ; (list
                           ; (list
                           ; "app12" ;name
                           ; "(load(findfile \"app12.LSP\"))" ;command
                           ; (strcat main_cad_folder "Icony\\" "KalkulatorTMZ.bmp") ;path to icon
                           ; "This button ..."                        ; help text
                         (setq Toolbar nil)
                         (vlax-for n (vla-get-toolbars (vla-item (vla-get-menuGroups (vlax-get-acad-object)) tgname))
                           (if (= (vla-get-name n) (car button_lst))
                               (setq Toolbar n)
                         (if (not Toolbar)(setq Toolbar (vla-add (vla-get-toolbars (vla-item (vla-get-menuGroups (vlax-get-acad-object)) tgname)) (car button_lst)))) ; tworzy nowy toolbar
                         (foreach button (nth 1 button_lst)
                           (progn
                               (print (nth 0 button))
                               (setq newToolbarButton
                                   (vla-addToolbarButton
                                       Toolbar
                                       (1+ (vla-get-count Toolbar))
                                       (nth 0 button) (nth 0 button) (nth 1 button)   ; name and command
                               (setq SmallBitmapName (nth 2 button))      ; path to icon
                               (setq LargeBitmapName (nth 2 button))
                               (vla-setBitmaps newToolbarButton SmallBitmapName LargeBitmapName)
                               (vla-put-helpString newToolbarButton (nth 3 button)) ; help
                         ;; re-compile the tgname menu, this part doesn't work on bricscad
                         ; (vla-save (vla-item (vla-get-menuGroups (vlax-get-acad-object)) tgname) acMenuFileCompiled)
                         ; save it as a MNS file
                         ; (vla-save (vla-item (vla-get-menuGroups (vlax-get-acad-object)) tgname) acMenuFileSource)
                         [/code]
                         [code]
                             (defun createToolbarGroup (tgname toolbarlist / fn flag) ;(createToolbarGroup "DJTT" '("Aplikacje" "Narzędzia"))
                                 ;;;; Createas toolbar Group
                                 ;;;; example (createToolbarGroup "DJTT" '("Apps"))
                                 (setq flag nil)
                                 (if (not (findfile (strcat tgname ".mns")))
                                   (progn
                                     (setq fn (open (strcat main_cad_folder tgname ".mns") "w"))
                                     (close fn)
                                 (vlax-for n (vla-get-menuGroups (vlax-get-acad-object))
                                   (if (= (vla-get-name n) tgname)
                                     (setq flag T)
                                   (terpri)
                                   (princ (vla-get-name n))
                                 (if (null flag)
                                   (vla-load (vla-get-menuGroups (vlax-get-acad-object)) (strcat tgname ".mns"))
                                 (foreach tb toolbarlist
                                   (vla-add (vla-get-toolbars (vla-item (vla-get-menuGroups (vlax-get-acad-object)) tgname)) tb)
                 [/code]
            it is, but now it is problem with add method (maybe i shouldn't start new topic)i need to find any alternative for that addbuttons function, any tips?0
            Your functions are case-sensitive for names. Maybe that causes your problem.0
            can You explain case-sensitive problem, i don't understand what You mean.0
            Example:
Your functions will try to create a toolbar "MYTOOLBAR" if a toolbar with the name "MyToolbar" already exists. Which will cause an error.
To avoid this you can do something like this:
[code](= (strcase (vla-get-name n)) (strcase (car button_lst)))[/code]
And:
[code](= (strcase (vla-get-name n)) (strcase tgname))[/code]0 -
            thanks guysi menage that by unload menugroup (if it already exist) and create new one0
