Is it possible to adapt the deafult color index ?
Hi there, I'm brooding over a problem with colors. Maybe someone has a hint for me. Where can I change the default color assignment Index <-> Color ?
I'm exporting a test-DWG from an extern CAD-application, 1 simple line element in it, layer number 190, color index 111.
In the extern application the color index 111 is a blue tone (this color-table has also numbers from 0-255).
Now when I open the DWG in Bricscad the line (layer 190, color index 111) comes in a green tone, because the color index 111 in Bricscad is set to this green tone by default. And this is exactly what I want to control from outside, before opening the DWG in Bricscad, give the indices the same colors as in the extern app (111 -> blue).
Thanks and a good day to you all, Peter from Munich, Germany
  • Hi Peter,
    To my knowledge the colour tables are fixed, it is not possible to change them. Options depend on what you are trying to achieve:
    • Ideally configure the application that your exporting from so that it maps to the correct colours for BricsCAD. Many CAD applications include this type of facility.
    • If the all the objects on the drawing have their colour set to bylayer, then you could use a simple script to update the layer colour settings.
    • An alternative to item above. You could set up a drawing with all the layers set to the correct colours, and if common blocks are involved you could also correct these (you would save this drawing as a template). You would then _INSERT the drawing you want to import, then explode. Because the layers and blocks are already defined in the target drawing, they will automatically take on these properties on insertion.
    • If the drawing contains blocks with explicit colour settings, then you probably want to investigate creating a routine to update. Roy Gebbinck created a fairly similar routine to this for dealing with truecolour https://forum.bricsys.com/discussion/11733
    Best regards,
    CAD Concepts
  • I never understood why Autodesk stuck to a fixed palette.
    I think there is a clear use case for user definable palettes:
    If several people in an office work simultaneously on a set of drawings, and some of them have a light graphics area background configured while others prefer a dark one, not all can have an ergonomically satisfying display (unless you use a script that converts colors each time a drawing is opened or saved, but that seems quite a clumsy solution).
    Maybe worth a feature request.
