Help me please!
Hello! uchusU write in VB.NET and first way I have a problem.
Learning language examples for AutoCAD.
One example works:
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.Runtime
 _
Public Sub SaveActiveDrawing()
  Dim acDoc As Document = Application.DocumentManager.MdiActiveDocument
  Dim strDWGName As String = acDoc.Name
  Dim obj As Object = Application.GetSystemVariable("DWGTITLED")
  '' Check to see if the drawing has been named
  If System.Convert.ToInt16(obj) = 0 Then
      '' If the drawing is using a default name (Drawing1, Drawing2, etc)
      '' then provide a new name
      strDWGName = "c:\MyDrawing.dwg"
  End If
  '' Save the active drawing
  acDoc.Database.SaveAs(strDWGName, True, DwgVersion.Current, _
                        acDoc.Database.SecurityParameters)
End Sub
the second example does not work:
Imports System.IOImports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.DatabaseServices
 _
Public Sub OpenDrawing()
  Dim strFileName As String = "C:\campus.dwg"
  Dim acDocMgr As DocumentCollection = Application.DocumentManager
  If (File.Exists(strFileName)) Then
      acDocMgr.Open(strFileName, False)
  Else
      acDocMgr.MdiActiveDocument.Editor.WriteMessage("File " & strFileName & _
                                                     " does not exist.")
  End If
End Sub
I changed the import libraries on BricsCad.
Why does not the second example. What is wrong? How to do this right?
