Global Rename
Using Autocad its possible to remove or add prefixes and suffixes to layer names by using the "rename" command and a wildcard.
However BricsCad doesnt appear to allow wildcards when using "-rename"
Is there an add-on or some other way to do this?
Thanks
I am also looking for this function in BricsCAD.This should be a little "coffee break task" for a programmer?Mustafa0
Raised an SR with this feature request??
Wild card referencing has been included for other commands where it was found missing .e.g -PSETUPIN
Regards,Jason Bourhill
I have a strong idea it used to work, but it doesn't in my v15.
I have used this lisp for a long time and it still works.
It just adds 880- to all layer names, or removes them if they are there.
If half the layers have it and half don't, it just transposes the mess but I can't be bothered fixing that.
(Defun C:880 ()
(SETVAR "CMDECHO" 0)
(SETQ A (TBLNEXT "LAYER" T))
(while (/= nil a)
(setq a (tblnext "layer") b (cdr (assoc 2 a))
(if (/= nil a)
(progn
(if (= "DEFPOINTS" b)(setq a (tblnext "layer") b (cdr (assoc 2 a))))
(if (= "0" b)(setq a (tblnext "layer") b (cdr (assoc 2 a))))
(if (= "880-" (substr b 1 4))
(command "rename" "la" b (substr b 5 (strlen b)))
(command "rename" "la" b (strcat "880-" b))
)0 -
I have a Lisp routine that I wrote a few months ago that will behave similar to the Rename command in AutoCAD. It will add and remove layer name prefixes to all layers or it can be used as a find and replace if you do not want all of the layers to be renamed. I will post it here later...
