Paper Space plot differences ver 12.1.4 - ver 14.1.11
I just started printing to PDF (Bluebeam) from ver 14.1.11
I see there is a difference between the results of same job from 12.1.4 to 14.1.11
12 plots whole of sheet, 14 truncates.
I normally select the exact edges of my sheet and traditionally that has worked every time.  They are standard A3 sheet sizes.
But only way to get all to plot is to select print window marginally outside the sheet extremities.
I had this happen in past with IntelliCad and was told that's how it's designed to work, but then I came to Bricscad and found otherwise.
Are there additional settings I am unaware of outside the Print settings that come up when Ctrl P is used, that I have missed?
I use Plot Scale 1, Centre on page, Portrait, millimetres, Plot area - Window.  I can't see any other area for changes. (other than increase the 'Windowed plot area'.)
I know that is the obvious(increase plot area), but as it didn't work like that before and it takes more care to chose beyond the page I'd prefer old ways.
help appreciated thanks.
Richard
