Installing Bricscad-V12.2.16 on Kubuntu 64bit
in Linux
I have bought Bricscad for linux (Bricscad-V12.2.16-2-en_US.deb) but i can't install it.
when i run it (click on it) i get Error: Wrong architecture 'i386' (attechment)
How can o solve this? Is there 64bit version? Is there a way to replace .deb and using the same license?
Thank you!
Thank you!
Bricscad is 32-bit application while your Ubuntu is clearly 64-bit. Maybee you have to enable 32-bit repository.0
Can you still buy V12? V14 is the current version.
There's no 64-bit V12 version, but V14 has 32 and 64-bit packages.
to run the 32-bit version you'll need the pertinent 32-bit compatibility packages as the poster above wrote.
If you can, update to V14, it's much better.0
