BricsCAD Load Time
 Recently BricsCAD seem to take for ever to load, periodically getting not responding grey outs and crashes. There is no particular task theat this seems to happen on. Has anyone else experienced this? DOes anyone have any suggestions?
  • Do you have an Anti-Virus software running ? Try with disabled AV then, to see if that makes a difference ?
    Many greetings !
  •  I've had the same experience. V14 takes almost a minute to load, compared to just a few seconds for V13 (on the exact same machine, OS, etc).
    Once it's loaded V14 seems to run just as fast as 13.
  • Mine loads very quickly. A little slower first time after starting the machine and using internet, my usual routine.
    I use minimal virus security with real time protection turned off, many would say that's not too smart but I don't have many OS issues.
  • Curious. I still have v13 on my netbook (w/ it's paltry Intel Atom processor) and v14 loads in 7-8 seconds, v13 takes a couple seconds longer.
    On desktop machine v14: 5MB dwg opens in <3 seconds.<br>
  • v14.2.06 opened here in about 3 seconds on my desktop on the first run of the day.  I have noted that the time to open a new instance of Bricscad can vary during the course of the day, but the most I recall it taking is around 15 seconds.  I run Bricscad with one drawing per instance of Bricscad so it is not unusual for me to have six or more instances open at any time.
