How to model eccentric cones
 Hi All,
can you help me regarding this point? is needed to make some eccentric reductions for pipes!
Thank You!
  • You can try to use the LOFTX-command by Konstantin Sakellaris or ask me for my (very old) RNDTORND.lsp to create surface- or 3DSOLID-models of
    eccentrical tansitions.
    Regards
    Jochen
    www.black-cad.de
  • Since BricsCAD does not yet feature lofting functionality, this needs a bit of labor, but you can do it without any add-ons - you just have to construct an elliptical cone and slice it to get the desired result.
    I don't have the time to write a full tutorial, if you like,  just try if the attached file gets you on the track: the red lines indicate the desired geometry, the cyan lines are intermediate geometry, and the green lines are the geometry of the elliptical cone.
    (After slicing the cone, I turned it into a pipe using the solidedit/body/shell command).
    eccentric_cone.dwg
  • Hi Adrian,
    since version 14.02.x you can loft eccentric Cones in Bricscad by using a Circle and a Point as Start and End Loft Profiles respectively.
    Download my plug-in at
    https://forum.bricsys.com/discussion/17053#22146
    and use the LOFTX command to loft any eccentric Cone you like !
    Attached you find an example drawing.
    Regards
    Konstantin
    eccentricCones.dwg
